OcarinaMaker
Mar 08, 2021Star
RBR50 After Firmware Update, Admin Login Credentials Don't Work
Hello! I purchased and installed my Orbi system last May 2020. I am technically proficient and had no issues setting the router up with my two satellites and after spending some time tweaking the ...
- Mar 08, 2021
OcarinaMaker wrote:However, today I initiated a firmware update from within the admin interface and after the update, it no longer recognizes the admin login information I've been using since I set it up almost 10 months ago. In fact, it was the very login I used to login to update the firmware this morning.
It also does not recognise the defaul login an Orbi router has when one first purchases the router, username: admin password: password.
The router prompts me to enter my security question answers in order to reset my password, but then tells me my answers are incorrect. They aren't. I had stored them. Also, since they were names of my family, I could hardly get them wrong, even if I hadn't stored them.
What a disappointment. Sorry this happened to you.
The short answer is: You're screwed and have to do a Factory Reset and reconfigure the Orbi.
https://www.youtube.com/watch?v=cMw4ePACgc4
Factory Reset is what sets the Orbi credentials to "admin" and "password".
Before making any 'serious' changes to the Orbi configuration, I now "Save" the configuration to my PC before the changes and after them. Doing a factory reset is vastly less work if the entire configuration can be loaded with one click. Saved me two hours when I wrecked the web interface using telnet and had to reset.
Password Recovery has failed for me (once) and worked for me (once). I never did figure out what caused the failure.
OcarinaMaker
Mar 08, 2021Star
Thank you for your reply. Though it was not what I hoped to hear, it is what I feared would be true.
I actually thought I had saved the settings, but I can't find the back up now.
Can you tell me what the file extension would be in the name of a Netgear router backup settings file?
vajim
Mar 08, 2021Master
OcarinaMaker wrote:Thank you for your reply. Though it was not what I hoped to hear, it is what I feared would be true.
maybe this will help
- OcarinaMakerMar 08, 2021Star
Yes, I know how to back up the configuration settings. I don't know how I forgot to do this on this setup. All I can find are the config backups for the router this one replaced. :-/
That was a mistake I regret.
- vajimMar 08, 2021Master
IF you use Google Chrome, perhaps this will help:
https://support.google.com/chrome/answer/95606?co=GENIE.Platform%3DDesktop&hl=en
