Svorde
Jul 11, 2019Aspirant
RBR50 After Firmware Update Laptop will not connect 5ghz
After my RBR50 with satellite firmware update, my Dell Laptop (Qualcomm QCA9377 802.11ac Wireless Adapter) does not connect at 5ghz but the 2.4ghz. The adapter is up to date and supports both bands...
Jul 12, 2019Guru - Experienced User
Is the Orbi system operating in Router or AP mode?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Try a factory reset on the RBR and setup from scratch.
Svorde wrote:After my RBR50 with satellite firmware update, my Dell Laptop (Qualcomm QCA9377 802.11ac Wireless Adapter) does not connect at 5ghz but the 2.4ghz. The adapter is up to date and supports both bands.
Is there something to check or change to get back to faster band? I apologize in advance if this is easy, old dog trying to learn new tricks. I searched but no joy,
Thank you in advance,
- SvordeJul 15, 2019Aspirant
What Firmware is currently loaded? [v2.3.5.30]
[I am not sure, it says router in network map]What is the size of your home? Sq Ft? [2,700 sf]
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected. [28 feet]What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
[I apologize, I cannot find manual channel]
Any Wifi Neighbors near by? If so, how many?[1 next door, but i put on ignore]
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).[I do not see those choices in the app]
[Tried this one, but same]
[I am obviously not well versed in computers, but truly appreciate your reply trying to help me]
- CrimpOnJul 15, 2019Guru - Experienced User
Ah, yes, the "app". Which causes so many posts that an entire Netgear community forum is devoted to it:
https://community.netgear.com/t5/Orbi-App/bd-p/en-home-orbi-app
Most of these options are present in the "web interface" which came with Orbi from the beginning. i.e. use a web browser and navigate to orbilogin.com (I, personally, use the IP address of the router, which shows up in the app.) My 'guess' is that Netgear believes options such as these are of no interest to the vast majority of customers and so does not offer them in the app. (Or, maybe they are there and I just do not know where. That's what the other forum is likely to know.)
What does the app show for the "link rate" on the laptop?
- FURRYe38Jul 15, 2019Guru - Experienced User
Please make any of the suggested changes by using a web browser and logging into the RBRs web page. This is where you'll find those features.
