Yogibara
Nov 01, 2022Aspirant
RBR50 After iOS Upgrade to 16.0 and MacOS to Ventura getting connectivity issues
First, it started with my recently upgraded M1 Macbook to Ventura. Getting SSL errors and logs indicate login refused. MacOS has been stable for the past few hours but my iPhone13 is still having iss...
Nov 01, 2022Guru - Experienced User
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first.
Be sure to disable any wifi private IP address features on Apple devices:
