SteinerMeister
Sep 26, 2023Aspirant
RBR50 Allowed devices not connected -- how to move to "Allowed"?
OS is Windows 10.
Sep 26, 2023Guru - Experienced User
Is this ethernet connected or wireless?
Did you log in to the RBRs web page and look under Advanced/Security/Access controls to see if it's blocked here?
- SteinerMeisterSep 26, 2023Aspirant
Both.
- FURRYe38Sep 26, 2023Guru - Experienced User
Let us know if you have Access Controls or maybe Smart Parental Controls or Circle enabled.
Just says "allowed devices not connected" which is ~45. only 2 devices remain connected.
- CrimpOnSep 26, 2023Guru - Experienced User
The Orbi web interface, Advanced Tab, Security Menu Access Control contains three tables:
- Every device is currently connected to the Orbi system (both wired and WiFi). When Access Control is Enabled, this tables identifies which devices are Allowed and which are Blocked. (Blocked meaning they cannot communicate.)
- The second table is Allowed devices which are not connected. Orbi maintains a record of every device which has been connected to that it will recognize when the device becomes connected again and know how to treat it.
Devices in this table are not connected to the network. - The third table is Blocked devices which are also not currently connected.
The only way to move a device from table 2 to table 1 is to connect it to the network.
I have only the 1st and 2nd tables. Several of the items listed in the 2nd table are very close to the router and, one would think, should be easily connected. Some items are named "Unknown:. Intruders?
