Milan81
Oct 06, 2020Guide
RBR50 and 3 RBS50: streaming issues during Zoom calls when connected to satellites, requests lagging
I have RBR50 working as AP connected to ASUS RT-N66R Router and three sats all over the house (RBS50). After my last update to V2.5.1.16 several months ago I noticed that when connected via satel...
Milan81
Oct 06, 2020Guide
Thank you very much for prompt reply.
1) I'm not quite sure about the distance - eqipment is on different floors, but it should be ok, since everything was working fine for couple of years until recently and I haven't moved sats or router.
2) channels. I'm already using channel 6 for 2.4Ghz and 48 for 5Ghz. I changed it from Auto because I used to have issues with Ring cams.
No Wifi neighboors except for wireless printer and guest wireless network from Orbi
3) never did factory reset since last update.
4) Never tried: Beamforming and MIMO (tried this when addressing Ring issues), Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz
I will try steps under No4 and will let you know
Thanks again!
Milan81
Oct 06, 2020Guide
And good question - should I try all these steps intead/before updating the firmware? There's new version available and probably it might solve my issue?
