Milan81
Oct 06, 2020Guide
RBR50 and 3 RBS50: streaming issues during Zoom calls when connected to satellites, requests lagging
I have RBR50 working as AP connected to ASUS RT-N66R Router and three sats all over the house (RBS50). After my last update to V2.5.1.16 several months ago I noticed that when connected via satel...
Oct 06, 2020Guru - Experienced User
Try the steps and see. If this doesn't change the problem, i would factory reset and setup from scratch.
Milan81
Oct 07, 2020Guide
Some intermediate results: I have tried all things, some of them are unavailbale since I'm using Orbi in AP mode, but majority are available.
So far the only thing that actually seems to solve my problem is Daisy Chain. I have turned it off although I have three sattelites. Before one of my sats was connected to router through the other sat, now all sats are connected to router directly. One of them shows yellow dot which stands for weak signal I guess, but the service is stable and speed is around 150 Mbs near that sattelite (it was 170 Mbs before). So I lost around 10% in speed but if it brings stability I'm ok with this.
Let me test this configuration for couple more days and I will let you know how it works.
Thank you!
- Milan81Oct 07, 2020Guide
ah and requests' lagging is gone for sure
- FURRYe38Oct 07, 2020Guru - Experienced User
AH I should have asked what mode your orbi was working in and if Daisy chain was enabled.
Sounds like it's working better for you with Daisy Chain disabled.
- sbeares1210Oct 15, 2020Guide
I'm having similar issues. Tried everything listed. Is yours still stable?
