gvboggs
Jul 28, 2021Tutor
RBR50 and ATT Fiber?
Hi, I have a RBR50 with 3 additional satellites. Worked great with Comcast internet. Just moved and the new neighborhood as AT&T Fiber. I thought I would give it a try. AT&T hardware (router) is ...
gvboggs
Jul 28, 2021Tutor
Worked great previously on Comcast with a cable modem. I'm past the initial set up now. Still struggling with getting the orbi to see the internet. Done for the night, resetting and trying again in the AM.
Jul 28, 2021Guru - Experienced User
Work with the RBR first with out the RBS online. Leave them OFF.
I'd call up the ISP and see if they can help you with there modem. IP pass thru should work with the RBR in router mode. Don't use IP pass thru with the RBR in AP Mode.
NIght.
