Windchaser
Feb 10, 2019Tutor
RBR50 and CM1150V compatibility
Hi, I am new to Netgear community. I also posted this within the CM1150V discussion group.
Six months ago I upgraded my network with the Orbi RBR50 and it was attached to the Comcast modem. ...
- Feb 10, 2019
Thank you ... I completely rebooted the CM1150V, Orbi and the satelites and the network is now back to 180 mbps.
I see where I went wrong, I just turned off/on the Orbi when I installed the CM1150V and did not go through the process of restaring everything from scratch. Thanks again.
ekhalil
Feb 10, 2019Master
Have you followed the instructions in the manual to connect the cable modem to a router as follows:
- WindchaserFeb 10, 2019Tutor
- FURRYe38Feb 10, 2019Guru - Experienced User
Glad you got it working. Yes, when chaning Modems or routers. It's always best to power both systems Down, make ths change and then power the modem on first, then router.
Enjoy. :smileywink:
