Teamoverton1
Apr 13, 2019Follower
RBR50 and CM1150V compatibility
I Installed the RBR50 Router and all of my WIFI multiple outlet power strips fail to pair. Does NetGear make a power strip that is compatible or recommend a 3rd party manufacturer that will pai...
Apr 13, 2019Guru - Experienced User
What FW is currently loaded?
NG doesn't make power strips...
Are these power outlets 2.4Ghz only?
Had they worked before?
