Jago3183
Sep 25, 2024Tutor
RBR50 and EE 4G
I’ve been using Orbi RBR 50 and two satellites with a Huawei 4G router in bridge mode with a Lyca mobile sim without issue for 6 months. I went over the fair use policy with lyca mobile so switched to...
CrimpOn
Sep 25, 2024Guru - Experienced User
There appear to be a number of Huawei 4G routers. Which specific model is this?
If it "works fine" without the Orbi, that means it has been switched back into router mode, correct?
What happens if the Orbi is connected at that point? (leaving the Huawei in router mode)
Every time the SIM is switched, both the Huawei and Orbi are powered off. Huawei started first, then Orbi, correct?
One would hope that EE and Huawei have user forums?
Jago3183
Sep 25, 2024Tutor
Hi, the router is a Huawei B535 and yes to test that it wasn’t just the sim I put it back into router mode and it works fine like that. As soon as I connect the orbi it doesn’t get internet.
Yes I am following that sequence when sim switching.
