Rodders693
Aug 31, 2019Aspirant
rbr50 and Fenix 5s+
I have recently updated my router and all seems well, other than my Fenix 5X+ watch no longer detects the wifi signal.
I pick up the wifi of all other sources and connect without issue.
Any advice?
- timchLuminary
I have a Fenix 5+ and it works perfectly with my Orbi RBK50.
- Rodders693AspirantMy one used to as well. But now doesn’t even see it as an option. All other devices are picking it up no problem.
- Blanca_ONETGEAR Employee Retired
Hi Rodders693
Is there an option to manually add the network? If so, can you please try it?
Blanca
Community Team- Rodders693AspirantYes it does, yes I have. It doesn’t work.
