Femur
May 10, 2020Follower
RBR50 and Google Assitant
Hi I have a Google Nest Hub. Using the Google Home App and a previous router, the set up proceeded fine. First Google Home would see Nest Hub with bluetooth. Then I would fill in some details on t...
May 11, 2020Guru - Experienced User
Femur wrote:Hi
Then I would fill in some details on the hub - room etc.
Then it would ask me to connect to the Hub to the Home Network by filling in Home Network password.
Now i have swapped out the previous router for and Orbi router.
All other devices have no problems connecting to the Router.
Connected to 'Orbi02' i go through the set up wizard on Google Home App
App sees Nest Hub with blue tooth.
I fill in the details for the Nest Hub, family room etc
I arrive at the Network picker - I've noticed two behaviours
If I have done a factory reset on the Nest Hub, I can see Orbi02 for one time.
I try to make a connection to Orbi02 - i input the password - the connection fails and I get a fail message on the app and on the nest hub.
If i try the setup wizard a second time, or (same thing) without a factory reset, then I don't see Orbi 02 in the network picker list.
I cannot connect to Orbi02 because i don't see it.
The first behaviour suggests that the Orbi02 rejects the connection from Google Nest Hub.
Then the Google Home App, remembers the fail and removes Orbi02 from list.
Is there a setting on Orbi02 that would allow the Orbi02 to accept the connection attempt from the Google Nest Hub.
Thanks for any help in advance!
