Jroach
Feb 25, 2020Luminary
rbr50 and IoT/Tablo issue, traffic getting lost
I have a Denon AVR, Apple AX (express), and Tablo that are all buggy...I think for the same reason. Working with Tablo (since it was new) they determined that: "Tablo's local traffic is being lost b...
- Feb 25, 2020
Temporarily reduce the transmit power level. I'll give this a try...I had done this in the past so familiar with the process but can't remember why I didn't leave it at a reduced power level.
Thanks for the tip.
Feb 26, 2020Guru - Experienced User
Daisy Chain is only for having two or more RBS out in a line from each other to piggy back there connections off each other. Does not effect Connections with signal RBSs.
Be sure your TVs fireware is up to date.
Did you reduce the power output of the RBR any?
Jroach
Feb 26, 2020Luminary
Yes, I did reduce the power. If it continues to work for a week then I would say that was the fix.
TV is at the latest FW ver.
For giggles, I'm going to turn off the Daisy Chain and see if it fails again. If so, maybe this is another symptom or indicator of my network traffic issues.
Thanks again.
- FURRYe38Feb 26, 2020Guru - Experienced User
Keep us posted.
- JroachFeb 26, 2020Luminary
Status:
1. TV connected to RBS (About 10' away)
Daisy Chain turned on
all works well
2. Turn Daisy Chain off
TV now shows connected to RBR at 2.4 (vs 5)
TV fails to connect
3. Unplug TV and replug
TV now shows connected to RBS
all works well
4. Rebooted Orbi (without changes)
TV goes back to being connected to RBR
TV Fails to connect
I guess in changing the Daisy Chain settings or any reboot of the RBR, the RBR becomes available first so the TV tries to connect. Reseting the TV causes it to reconnect to the closest point (RBS) at 5Ghz.
If that's the case, shouldn't Orbi allow broadcast first from the RBS then RBR?
It's up to client devices to pick which signal it connects too. Not the Orbi. Orbi only provides the platform for devices to connect. So you proved this by when you unplugged the TV then back ON. it picked the RBS signal.
I also noticed this for the Denon AVR (which sits near the TV).
Wouldn't it be more effecient for the RBS to come up first? I understand that the
client device picks but it's picking 'first available' and in my case first available is a bad choice.
I'm going to reduce 2.4 to 25% and see how it goes.
IF you reboot the RBR, then the devices should connect to the RBS since it's still up and running.
The reduction in power on the RBR should help here...
