Jroach
Feb 25, 2020Luminary
rbr50 and IoT/Tablo issue, traffic getting lost
I have a Denon AVR, Apple AX (express), and Tablo that are all buggy...I think for the same reason. Working with Tablo (since it was new) they determined that: "Tablo's local traffic is being lost b...
- Feb 25, 2020
Temporarily reduce the transmit power level. I'll give this a try...I had done this in the past so familiar with the process but can't remember why I didn't leave it at a reduced power level.
Thanks for the tip.
Jroach
Feb 26, 2020Luminary
I also noticed this for the Denon AVR (which sits near the TV).
Wouldn't it be more effecient for the RBS to come up first? I understand that the
client device picks but it's picking 'first available' and in my case first available is a bad choice.
I'm going to reduce 2.4 to 25% and see how it goes.
Feb 26, 2020Guru - Experienced User
IF you reboot the RBR, then the devices should connect to the RBS since it's still up and running.
The reduction in power on the RBR should help here...
