abimor
Nov 10, 2017Aspirant
RBR50 and RBS50 constantly dropping
so I have a router and 1 satelite that are constantly dropping the satelite crashes about every ten minutes. I followed the advice in this thread https://community.netgear.com/t5/Orbi/Orbi-satellite-...
Retired_Member
Nov 10, 2017Move the sat closer to the router.
- abimorNov 10, 2017Aspirant
it was working fine until about a month ago, since then its been droping. its distance to the router is not the problem there are no walls in between its a straight shot less then 20 feet.
- Retired_MemberNov 11, 2017
2 things... wireless environments do not remain static. Distance between the sats and the routers decreased with the 2.0.x releases. If they're disconnecting, move the sat closer, whether that is 50 feet or 10 feet. If the sat can't connect to the router, then clients connected to the sat will not work.
