drfrink24
Feb 28, 2020Aspirant
RBR50 and RBS50 Ethernet stopped working
1 RBRv2 and 1RBSv2, been working fine for several months Around 9pm CST last night, all my connected ethernet devices quit functioning, wireless devices are working fine; Actions taken, with no ...
- Feb 29, 2020
Tried two switches in the configuration, identical problems for both, so it was something on either both or one of the PCs. Problem went away when I booted them to their OS.
Feb 29, 2020Guru - Experienced User
What is the Mfr and model# of the ethernet switch in the configuration?
Did you remove the switches from the configuration and try again?
drfrink24
Feb 29, 2020Aspirant
- FURRYe38Feb 29, 2020Guru - Experienced User
What is the Mfr and model# of the ethernet switch in the configuration? Just wondering.
Glad the boot to OS fixed it. Odd that PC held at BIOS should cause network problems. Network isn't active at BIOS.
Please mark your thread as solved so others will know.
