TheLastMohican's avatar
Dec 07, 2019
RBR50 and RBS50 stability issues
Hello everybody. I hope some of you might be able to help. First time post so be nice :)   I bought a large house last year that is about 6000 sqft over 3 levels with brick walls. I knew wifi was g...
  • tucsontico's avatar
    Dec 07, 2019
    In my opinion, the problem is the firmware version you are running. 2.5.0.38 has been pulled by Netgear due to problems you've mentioned. I would revert back to 2.3.5.30. After that reversion, do a factory reset and run the setup wizard from scratch. It is a bit of work but should get you a more stable WiFi enviroment.
