TheLastMohican
Dec 07, 2019Tutor
RBR50 and RBS50 stability issues
Hello everybody. I hope some of you might be able to help. First time post so be nice :) I bought a large house last year that is about 6000 sqft over 3 levels with brick walls. I knew wifi was g...
- Dec 07, 2019
In my opinion, the problem is the firmware version you are running. 2.5.0.38 has been pulled by Netgear due to problems you've mentioned. I would revert back to 2.3.5.30. After that reversion, do a factory reset and run the setup wizard from scratch. It is a bit of work but should get you a more stable WiFi enviroment.
TheLastMohican
Dec 07, 2019Tutor
Thanks tucsontico I shall give this a try.
I hadn't actually realised that it was possible to roll back firmware.
Do the satellites have to be updated separately or can it all be done at the same time? Do you know if there is a walk you through it guide?
tucsontico
Dec 07, 2019Virtuoso
To do the reversion properly you MUST revert the satellites first then do the router. You will lose connectivity to the satellites while the process is running and your WiFi will drop out also. Its best to do all the firmware work with a computer hardwired (etehrnet cable) to the router and NOT via WiFi.
