franciumf
Dec 07, 2021Aspirant
RBR50 and RBS50 Unable to Sync no matter what i tried
RBR50 unable to sync with RBS50 x3 i have 3 satellite that i want to sync with the router, router and satellites are all factory resetted, but satellites always show solid magenta unless if i u...
franciumf
1.8 is currently loaded for rbr and 3 satellite.
Tried all at once, and one by one while the others are powered down. Tried side by side, and even putting abit of distance between them with no obstacle.
Dec 07, 2021Guru - Experienced User
I would not have loaded v1.8.
Does walking thru the setup wizard on the RBR help any with adding 1 RBS?
Possible the system is faulty or the RBR is faulty. IF this is new, I'd return it for another system. Or contact NG support and see what your options are for an RMA.
