deborahmce
Oct 23, 2023Aspirant
RBR50 and RBS50
I've had the above Orbi products since 2019 with no issues. Firmware: v2.7.4.24 The router has been dropping the internet connection once daily for the past three days. A reboot of both modem a...
Oct 23, 2023Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
Does the top ring LED on the RBR turn PINK when this happens?
https://kb.netgear.com/31030/What-do-the-LEDs-on-my-Orbi-mean
IF the RBR is losing the connection, might that the ISP modem is not giving good services as well. The RBR depends on the ISP modem/ONT to give too services or it won't work right and exhibit problems caused by the ISP modem/ONT or ISP services. Something to talk to the ISP about.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-router
https://kb.netgear.com/25722/How-do-I-reserve-an-IP-address-on-my-NETGEAR-router
I would power OFF the ISP modem for 1 minute. Factory reset the Orbi router and power it off. Power ON the ISP modem and let it sync. Then power ON the Orbi router and walk thru the setup wizard again using a wired PC and a web browser.
Press the back reset button for 15 seconds then release.
https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
https://kb.netgear.com/000062081/How-do-I-erase-the-configuration-settings-on-my-Orbi-WiFi-System
Your behind on FW as well:
- deborahmceOct 24, 2023Aspirant
Thank you so much, I'll go through your questions and suggestions. Appreciate you!!
- FURRYe38Oct 24, 2023Guru - Experienced User
