PBO67400
Oct 02, 2021Aspirant
RBR50 and RBS50Y synchronization pb.
Hello, I have a RBR50 and a RBS50 setup, which has been operating for 3 years. And I buy RBS50Y, to add outdoor. But the synchronization does not work correctly, the state remains in "synchronizat...
- Oct 02, 2021
Hello, Thanks for answer.
Yes , I know these two mode, the question here is in Orbi mode, and App mode.
I think I have found a solution, the firmware updating doen't work with Safari and Firefox (MacOs), but it works with Chrome !
And it takes very very long to update.
So, now it 's Ok
CrimpOn
Oct 02, 2021Guru - Experienced User
The RBS50 has two 'modes':
- As an extender that works with any WiFi router, and
- As an Orbi satellite
Page 2 of the installation guide shows how to make sure the device is in the satellite mode
https://www.downloads.netgear.com/files/GDC/RBS50Y/RBS50Y_QSG_EN.pdf
Although the guide implies that the satellite should be mounted first, the general advice on the forum for adding any satellite (including the RBS50Y) is to place the satellite in the same room as the router for the initial setup. Once it is working correctly, then mount it outside.
- PBO67400Oct 02, 2021Aspirant
So, now it 's Ok
