JDOGLINDY
May 21, 2021Aspirant
RBR50 and Satellite - where is the setting to upgrade the allowed speed in?
How to change line in speed? I changed from 100 megs to 1,000 megs from ISP. Router needs to have setting changed and I can't find where to do that.
JDOGLINDY
Thank you for the quick reply. In the statistics section the WAN, it shows status of “100M/Full” and not 1000M/Full. My ISP said it should be changeable in the router settings somewhere. He also said CAT5E or CAT6 should be both rated at 1000Megs.
I have CAT5E from the ONT to the Orbi. I just downloaded the latest firmware which is V2.7.2.104. Manufacturer of the ONT is ADTRAN – model GPON 452.
CrimpOn
May 21, 2021Guru - Experienced User
JDOGLINDY wrote:Thank you for the quick reply. In the statistics section the WAN, it shows status of “100M/Full” and not 1000M/Full. My ISP said it should be changeable in the router settings somewhere. He also said CAT5E or CAT6 should be both rated at 1000Megs.
There is no setting. I would try a different ethernet cable.
