mrstucci1972's avatar
Dec 01, 2017
RBR50 and the Netgear AC750 Extender... Will they work together?
Before I got my Orbi (RBR50) I was using a Netgear AC750 and I would like to use it in one spot rather than forking over a hundred+ dollars to buy another satellite. I tried to set it up but it doesn...
  • Retired_Member's avatar
    Retired_Member
    Dec 01, 2017
    The AC750 cannot connect to the the backhaul of the Orbi.  It can only possibly connect as a extender of the primary Orbi networks, thereby defeating the purpose of having an Orbi system.
