ChrisRM
Oct 27, 2022Aspirant
RBR50 and very old wifi....
I'm trying to resurrect an old Sony Vaio laptop (TR1MP) and it doesn't support the encryption used by the RBR50 kit (PSK/AES). Instead it has WEP or nothing; is there any way of getting this to conne...
Oct 27, 2022Guru - Experienced User
if its got usb ports, you could try an upgraded usb wifi card in it. Just make sure the card is compatible with your system.
