EricMatson
Aug 16, 2018Follower
RBR50 Antivirus?
I just got the kit from Costco. It had 1 RBR50 and 2 RBS50 in it. Is this the same as the RBK50? I was also wondering if there is any antivirus available for this router. I wasn't aware I was goi...
Aug 16, 2018Guru - Experienced User
Home networking devices like routers and access point do not support anti virus programs. Those programs are needed for PCs and laptops where they look for malicious files and such on the PC. Circle support is a device management system where you can set up scheduling to block certain devices for your children or others on your network to give them access during specific time frames and I believe you can block sites or give access.
- RocketSquirrelAug 16, 2018Luminary
Au contraire, mon ami. Current firmware on some Asus routers performs anti-virus functions.
AiProtection with Trend Micro uses real-time network monitoring to detect malware, viruses and other intrusions before it reaches your PC or connected devices. Parental Controls let you schedule times that a connected device is able to access the Internet. You can also restrict unwanted websites and apps.
- Router Security Assessment
- Malicious Sites Blocking
- Vulnerability Protection
- Infected Device Prevention and Blocking
