cramm
Mar 06, 2020Aspirant
RBR50 AP mode with one RBS50 but in app shows satellite disconnected when connected to a switch
Hello community, I have some issues with my setup and i would like to share it with you. My setup is like this: Cisco Router<->switch<->RBR50 (AP mode) and the satellite RBS50 is connected t...
- Mar 07, 2020
I just got it working!!!
I connected both RBR and RBS to the cisco router. I got the ethernet backhaul working both on RBR web interface and in the android app.
Everything seems connected! FYI, i have connected the utp cable to the LAN port of RBR and to make the magenta ring dissapear i just connected a NAS (any always-on connected device will do).
Thank you everybody!
Mar 06, 2020Guru - Experienced User
Put the switch behind the RBR or put a switch behind the RBR then connect the RBS:
RBR and RBS need to be on the same segment with a switch. Your configuration puts the switch ahead of the RBR though technically it should work, some switches don't pass all Orbi Traffic. Some managed switch may not work well. Try D-Link DGS-105/8 series switches. These do work.
cramm wrote:Hello community,
Cisco Router<->switch<->RBR50 (AP mode) and the satellite RBS50 is connected to the switch.
The switch is a d-link DGS-1210-08P which is a managed switch but i havent used any vlans yet. Power saving, STP, IGMP all is off so i dont have the problems i read in previous posts.
I have also changed the ip to a 10.10.10.x/24 network and with dhcp from the cisco using mac addresses to provide static ips.
• When i am connecting to the app from my mobile, the app recognise the RBR50 but the satellite showing disconnected.
• When i am connecting to the app from the satellite, it doesnt recognise the RBR50 device, so i am entering only remotely but still the satellite showing disconnected.
The only way to make it work, is to put the RBS50 back2back with RBR50. Then it is working, but i can't have that setup because of the wiring of my house. I have tried a dummy switch to connect the orbi devices but still the same behaviour.
My house is about 200m2 and wanted to have each device to one floor. One other question is that i have the satellite to one end of the floor and when connecting through my mobile to the other side of the floor i get max ~30mbit. Is that ok, or i should get better than this?
Anyway, if you have any ideas/suggestions that you will help me, please reply.
Thanks & BR
cramm
Mar 07, 2020Aspirant
Hi again,
The d-link switch and cisco router is in the same place. The RBR goes to the LivingRoom through a utp cable which is connected to the d-link switch and the satelite uses the same setup to the first floor.
I tried to connect the RBR and RBS through this: https://kb.netgear.com/000051205/What-is-Ethernet-backhaul-and-how-do-I-set-it-up-on-my-Orbi-WiFi-System
and use the lan port, not the wan of the RBR but a solid magenta came in.When i plug the utp to the WAN port then the magenta goes off.
I have read a lot of opinions here but which is the right one when connecting to AP mode?
Thank you
- FURRYe38Mar 07, 2020Guru - Experienced User
What is the model# of the switch?
Managed and or having Green Ethernet features? If so, disable any IGMP protocols on the managed switch along with any Green Ethernet features if possible.
For non manged switches, if it has green ethernet features, you may have to get something with out. I know that D-Links DGS-105/108 series switches works fine with Orbi...
- crammMar 07, 2020Aspirant
Glad you got it working.
Enjoy. :smileywink:
