cramm
Mar 06, 2020Aspirant
RBR50 AP mode with one RBS50 but in app shows satellite disconnected when connected to a switch
Hello community, I have some issues with my setup and i would like to share it with you. My setup is like this: Cisco Router<->switch<->RBR50 (AP mode) and the satellite RBS50 is connected t...
- Mar 07, 2020
I just got it working!!!
I connected both RBR and RBS to the cisco router. I got the ethernet backhaul working both on RBR web interface and in the android app.
Everything seems connected! FYI, i have connected the utp cable to the LAN port of RBR and to make the magenta ring dissapear i just connected a NAS (any always-on connected device will do).
Thank you everybody!
cramm
Mar 07, 2020Aspirant
Hi again,
The d-link switch and cisco router is in the same place. The RBR goes to the LivingRoom through a utp cable which is connected to the d-link switch and the satelite uses the same setup to the first floor.
I tried to connect the RBR and RBS through this: https://kb.netgear.com/000051205/What-is-Ethernet-backhaul-and-how-do-I-set-it-up-on-my-Orbi-WiFi-System
and use the lan port, not the wan of the RBR but a solid magenta came in.When i plug the utp to the WAN port then the magenta goes off.
I have read a lot of opinions here but which is the right one when connecting to AP mode?
Thank you
Mar 07, 2020Guru - Experienced User
What is the model# of the switch?
Managed and or having Green Ethernet features? If so, disable any IGMP protocols on the managed switch along with any Green Ethernet features if possible.
For non manged switches, if it has green ethernet features, you may have to get something with out. I know that D-Links DGS-105/108 series switches works fine with Orbi...
- crammMar 07, 2020Aspirant
- FURRYe38Mar 07, 2020Guru - Experienced User
Glad you got it working.
Enjoy. :smileywink:
I have written it on my inital post.
The switch is a d-link DGS-1210-08P.
Does anybody know what kind of communication is between the orbis so that a cisco router can handle but not a switch?
