cramm
Mar 06, 2020Aspirant
RBR50 AP mode with one RBS50 but in app shows satellite disconnected when connected to a switch
Hello community, I have some issues with my setup and i would like to share it with you. My setup is like this: Cisco Router<->switch<->RBR50 (AP mode) and the satellite RBS50 is connected t...
- Mar 07, 2020
I just got it working!!!
I connected both RBR and RBS to the cisco router. I got the ethernet backhaul working both on RBR web interface and in the android app.
Everything seems connected! FYI, i have connected the utp cable to the LAN port of RBR and to make the magenta ring dissapear i just connected a NAS (any always-on connected device will do).
Thank you everybody!
Mar 07, 2020Guru - Experienced User
What is the model# of the switch?
Managed and or having Green Ethernet features? If so, disable any IGMP protocols on the managed switch along with any Green Ethernet features if possible.
For non manged switches, if it has green ethernet features, you may have to get something with out. I know that D-Links DGS-105/108 series switches works fine with Orbi...
cramm
Mar 07, 2020Aspirant
