leforban
Mar 20, 2021Aspirant
RBR50 as AP speed cap
Hi, It has now been a few days, my down and up speeds are limited to 24Mbps. I tried to downgrade the firmware from 2.7.2.104 to 2.7.2.102 but it didn't make any difference. When plugging an AP...
- Mar 20, 2021
Hey thank you for your answer.
I just resetted the thing and everything is back to normal !
300 down and 20 up ;-)
Thanks
tak1313
Mar 20, 2021Luminary
If you don't have older legacy devices, turn off 20/40 Mhz coexistence (if you have it on). It can slow your wirelss speeds significantly and most people don't need it anymore.
