ClaudeTiger
Aug 20, 2021Aspirant
RBR50 Attached Device has 2 ip addresses
Have RBR50 with one satellite. I have a smart thermostat (Ecobee) that I attached to the network with no trouble. The assigned ip address was typical, 10.0.0.(last assigned address + 1). Some months later I noticed that a second ip address was assigned to the same device, in the range of 169.254.77.yyy. I have no idea why, this has not happened with any other attached device. I also have a second thermostat, exactly the same model, both bought at the same time. The only difference is, because of location, the satellite may have the signal of the one with two ip addresses, and the other thermostat likely links directly to the router. Is this a problem? Why did this happen? Can I just dump the 169 address? Should I just reinstall? Comments welcome! Thank you!
1 Reply
Sort By
a 169 IP address means that the device was unable to get an IP address from the network, and thus is not on the network.
https://en.wikipedia.org/wiki/Link-local_address
I would set it up again.
