WDahl
Jun 25, 2021Follower
RBR50 automatically setting up as a 10.1.1.1 subnet
I now have a ATT fiber ISP with it setup as PassThrough. The ATT Router is 192.168.1.254 The Orbi Router on Advanced Internet is setup with the following: Internet Setup TAB IP 192...
Jun 25, 2021Guru - Experienced User
Using 10.0.something isn't a bad thing either. Just your ATT Modem uses .1.1 on its LAN and does the RBR. So the RBR moves to 10 to avoid conflicts. You can set the RBR to use .0.1 or even you can change the modems IP address to use .0.1 and then you can set the RBR to .1.1 if you want to.
WDahl wrote:I now have a ATT fiber ISP with it setup as PassThrough.
Internet Setup TAB
IP 192.168.1.1
Mask 255.255.255.0
Gateway 192.168.1.254
Use these DNS Servers
Primary 192.168.1.254
Router MAC AddressUse This MAC Address XXXXXXX
Use Router as DHCP Server Checked
Starting IP 192.168.1.2
Ending IP 192.168.1.254
Next go to the LAN Setup TAB
I can change the
IP Address to 192.168.1.1
Subnet Mask 255.255.255.0
An it keeps changing the IP back to 10.0.0.1 WHY??????
