n4cho
May 26, 2019Apprentice
RBR50 Backhaul Satellite Issue?
I have two satelites (RBS50) connected to my RBR50. One of these is wired via an ethernet cable run back to a switch which is connected to the RBR50. The wires sattelite is connected and devices co...
n4cho
Thanks for the reply - here are the details.
I am running firmware 2.3.1.60.
the orbi is in router mode.
The managed switch is an engenius ews7928p. Stp is set to stp per this - https://forum1.netgear.com/t5/Orbi/Orbi-Ethernet-Backhaul-with-Managed-Switches/td-p/1613897
i can see that all traffic is routing through the Ethernet port on this switch connected to the orbi.
Daisy chain is disabled.
i do have a single ssid for wireless.
Cheers,
Arthur_Dent74
May 27, 2019Aspirant
I have the same issue with the .60 firmware in AP mode. Tech support has been useless.
