lando786's avatar
lando786
RBR50 Backhaul Unreliable
I'm having a lot of issues with my RBS50 sattelite not being able to have a consistent connection to the RBR. Backhaul status was repeatedly switches between config sync and good while on wireless ba...
  • FURRYe38's avatar
    Nov 15, 2019
    Some config sync issues stem from users separating the SSID on the RBR which is not supported. Have you done this?
    What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
    Has a factory reset and setup from scratch been performed since last update?
