TC10
Apr 29, 2021Tutor
RBR50 basic Internet status glitch (
RBR50 with current firmware V2.7.2.104 Is anyone else getting this glitch on the basic status page? I continuely get this error that I am not connected to the Internet even though I am connected....
Apr 29, 2021Guru - Experienced User
Please use the Choose File button when you post to include your capture files as these can be downloaded and reviewed. Inline Pictures have to be approved by the forum moderator.
- TC10Apr 29, 2021Tutor
ok, it does not look like I can delete or edit my post so I guess I have to leave it to the forum moderators.
The Shaw modem info
https://support.shaw.ca/t5/internet-articles/hardware-information-hitron-cgnm-2250-docsis-3-0-wifi-modem/ta-p/6289#content-section-1- FURRYe38Apr 29, 2021Guru - Experienced User
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopI would also power OFF the ISP modem and RBR for 30 seconds, then back ON with the modem first, then RBR.
I have 4 Nestcams that will only run on 2.4GHz network in Canada. I also live in an older stucco (faraday interference) house with an addition so the wifi does not get around the house.
End result is that I require 3 wifi networks for the Nestcams in different areas of our home.
So I need the Orbi network for 1 Nestcam, the Shaw Hitron wifi network for another Nestcam and I have a Dlink powerline wifi for 2 more Nestcams. All working fine, currently.
These Nestcams have been working fine (mostly) for a few years until recent Orbi network upgrades.
The Nestcams are all working fine, I just get the orbi sometimes flashing white, sometime magenta and this glitch even though the Orbi is showing 130Mb download and 15Mb upload in the Orbi RBR50 speedtest in browser and iPhone app.
Also "I would also power OFF the ISP modem and RBR for 30 seconds, then back ON with the modem first, then RBR. " I have doen this several times.
