DerrickArdron
Nov 03, 2020Aspirant
RBR50 Blocking Prime, iPlayer, Netflix but we can watch YouTube
With our television connected to our Orbi we cannot watch Prime, iPlayer or Netflix but if I use a BT Home Hub and PoE to get the signal to our television all these services work. We are therefor...
- Nov 04, 2020
Fixed by reading the reccomended sismilar problem https://community.netgear.com/t5/Orbi/Netflix-Amazon-Prime-not-connecting/m-p/1964362#M100840
Problem was solved by changing MTU setting to 1472. It was previously 1492.
Nov 03, 2020Guru - Experienced User
What mode is your modem working in? Bridge would be preferred. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
- DerrickArdronNov 04, 2020Aspirant
- FURRYe38Nov 04, 2020Guru - Experienced User
Enjoy. :smileywink:
