quail
Jul 20, 2020Aspirant
RBR50 bricked after 2.5.1.16
For the first time after several months I used the Orbi app to check if there was any firmware upgrade to my router and satellites. The app told me there is a firmware upgrade to version 2.5.1.16. I ...
Jul 20, 2020Guru - Experienced User
Try this with the RBR, it should recover:
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
I recommend NOT using Orbi app to do any FW updates. Either check the RBRs web page with a PC for updates, or manually download FW files and apply with with a PC or laptop directly.
quail
FURRYe38 thanks for the suggestions.
but I'm stuck on this step
> Watch the Power LED. It starts with an orange color, and then start flashing.
When I turn on the router while holding down the reset button, it start with green instantly. No orange or flashing.
Anything else I can try?
- FURRYe38Jul 21, 2020Guru - Experienced User
Try skipping the Orange LED.
- quailJul 21, 2020Aspirant
Thanks again for your suggestion FURRYe38. I spent my entire day on this and tried all the solutions posted in various forums. No luck. I went to Costco to return it and they took it even though I used it for 13 or 14 months. They asked why I was returning and I just said firmware upgrade via app bricked my router. I bought the Google Nest router with 3 satellites. Costco has newer version of Orbi for $499 but I was not willing to take any chance because of this experience.
Ok. Sorry it didn't work out.
Good Luck.
