SCN's avatar
SCN
Rbr50 bricked after latest firmware update
My rbr50 went through the firmware update cycle and appears to have bricked itself. The green led power light is green and solid. The reset button does nothing no matter how long I hold it down the light at the top of the unit doesn’t come on. Anyone have any thoughts/suggestions?
  • CrimpOn's avatar
    CrimpOn
    One user suggested this procedure to restart an Orbi:
         If the regular factory reset process doesn't work, @michaelkenward described an undocumented way to get an Orbi to factory reset:
         Press paperclip in reset hole for 30 seconds
         Keep pressing paperclip while removing power
         Keep pressing paperclip for another 30 seconds while apply power
    If repeated attempts are not successful, there is a process to use the Trivial File Transfer Protocol (TFTP) to load firmware on any Netgear router.  I have done this with Orbi's.  It is not for the "faint of heart", but when the situation is desperate......
    https://kb.netgear.com/000059633/How-to-upload-firmware-to-a-NETGEAR-router-using-TFTP-client
    • SCN's avatar
      SCN
      Thanks I’ve tried the alternate reset method and it doesn’t behave any differently then the regular one. I haven’t tried tftp as it doesn’t issue an ip address either on wireless or through hardline so I assume I can’t send anything via a network transfer. Anyone know of a way to have it read/load firmware straight off a USB key? I will give the tftp approach a try since I can assign a static ip and try and route to it that way.
      • SCN's avatar
        SCN
        Neither method of doing a reset results in an addressible device.  I'm guessing this thing is truly a door stop at this point.  Which is irritating given that it worked perfectly fine before updating itself.
