Mooose
Aug 09, 2021Luminary
RBR50 bricked again, during update to 2.7.3.22, power LED only sold green
Man am I sick of this! I have been putting off updating to 2.7.3.22, but decided to try it because I want the security fixes. After "update all" from the web GUI the wifi came up again as exp...
CrimpOn
Aug 09, 2021Guru - Experienced User
I have a similar issue with 2.7.3.22 on one Windows 10 laptop. The URL entry is really sensitive. Sometimes I enter http://10.0.0.1 and it goes bonkers. Other times, it works correctly.
I suggest a few more tries, perhaps with different browsers.
- MoooseAug 10, 2021Luminary
CrimpOn wrote:I have a similar issue with 2.7.3.22 on one Windows 10 laptop. The URL entry is really sensitive. Sometimes I enter http://10.0.0.1 and it goes bonkers. Other times, it works correctly.
I did try a few different browsers, on different devices.
Regrettably I am way past that now, the device isn't offering an SSID, responding to ping or even reacting in any way to any of the reset procedures I've tried.
