Mooose
Aug 09, 2021Luminary
RBR50 bricked again, during update to 2.7.3.22, power LED only sold green
Man am I sick of this! I have been putting off updating to 2.7.3.22, but decided to try it because I want the security fixes. After "update all" from the web GUI the wifi came up again as exp...
wwlen1
Oct 11, 2021Guide
I don't know if this is too late for you, but my I had to load firmware into my RBR40 and only got the green light like you said.
After trying may things, I noticed that if I held the reset button in while booting the light flashed (orange/red), but went to green as soon as I released it.
I tried again and could ping it at 192.168.1.1 while holding in the reset and the light was flashing (after power on).
I then tried to do the tftp while still holding down the reset button and it worked.
Good luck.
Good luck.
Mooose
Oct 30, 2021Luminary
I do not get any reaction at all holding in the reset button, during power-up or otherwise. Still tried pinging 192.168.1.1 during boot with and without the reset button. Nothing.
