bmelvin
Aug 22, 2018Guide
RBR50 BRICKED during update to 2.1.4.16
My Orbi system - an RBR50 with two RBS50 satellites - had been working fine for a year or more. Not being an avid reader of the Netgear forums, I made a fatal mistake: I trusted the Orbi's software t...
- Aug 22, 2018
Thanks, FURRYe38 - The link you provided is broken, but googling turned up this page, which is probably the new version of what you were pointing to:
https://kb.netgear.com/000059633/How-to-upload-firmware-to-a-NETGEAR-router-using-TFTP-client
And, yes, it did the trick.
Dustin278
Aug 22, 2018Apprentice
bmelvin wrote:
My Orbi system - an RBR50 with two RBS50 satellites - had been working fine for a year or more. Not being an avid reader of the Netgear forums, I made a fatal mistake: I trusted the Orbi's software to work as designed over a wireless connection. The software reported that my Orbi router and satellite firmware (2.1.4.12, I believe?) was out of date, and said 2.1.4.16 was available. I clicked Update All. I waited a couple of hours and the Orbi was still blinking white. Eventually, I gave up - and prayed that power-cycling would make something happen. It didn't. Things went from bad to worse. Long story short, I'm able to connect to both satellites over Ethernet, and it appears that both were updated to 2.1.4.16. However, the router is totally bricked. It won't boot, and won't be reset. I can't get an IP address for it (I'm using a Mac, looking at the Network panel), can't reach it at all (tried pinging, tftp'ing, etc.). Sometimes, when I power-cycle it, the power LED is green. Sometimes it turns to flashing red. The top light flashes white, ad nauseum. Is there anything I can do?
Did you stick a pin in it to do a factory reset while the router has been on for at least a couple minutes?
- bmelvinAug 22, 2018Guide
Thanks for the reply. Yes, I tried every idea from this forum, including the TFTP method of restoring the firmware. The instructions for the TFTP method assume you're using Windows. The first time I tried to translate the instructions to MacOS, maybe I left something out, or the Orbi wasn't in the correct mode. The second time - just a few minutes ago, I got the file transfer to work, and the router came back to life. Now, after re-configuring everything, I'm back in business.
