bmelvin
Aug 22, 2018Guide
RBR50 BRICKED during update to 2.1.4.16
My Orbi system - an RBR50 with two RBS50 satellites - had been working fine for a year or more. Not being an avid reader of the Netgear forums, I made a fatal mistake: I trusted the Orbi's software t...
- Aug 22, 2018
Thanks, FURRYe38 - The link you provided is broken, but googling turned up this page, which is probably the new version of what you were pointing to:
https://kb.netgear.com/000059633/How-to-upload-firmware-to-a-NETGEAR-router-using-TFTP-client
And, yes, it did the trick.
bmelvin
Aug 22, 2018Guide
Aug 22, 2018Guru - Experienced User
Ok, i think my copy and past from a different post was truncated. Glad it worked out.
Enjoy. :smileywink:
