javuda
Dec 15, 2022Aspirant
RBR50 bricked, flashed and now behaves strangely
Hi. A few days ago my RBS50 wasn't connecting to the router. The ring light was turning on and off white. Factory reset wasn't working (pin turned the power led red). Investigating a bit I got to th...
Dec 15, 2022Guru - Experienced User
Try a 30-30-30 reset?
javuda
Yep. no luck
- KevinLiTDec 15, 2022NETGEAR Moderator
Hello javuda,
Welcome to the NETGEAR Community!
I understand that you are having issues with your RBS50. Since you attempted to solve the issue via TFTP i would like to endorse you to one of our experts for additional help.
Please PM the following information so I can endorse you to our support team:
Name:
Email:
Phone Number:
Device Model:
Firmware:
Serial Number:
Preferred time to be contacted:
App version:
Please provide this information as soon as possible!
I look forward to hearing from you!
Best,
Kevin
Community Team
