Orbibrick
Mar 14, 2018Aspirant
Rbr50 bricked itself
My Orbi router started kicked off all of our devices saying that the password was incorrect, but we hadn’t changed our password. I then tried to cycle the power off and on but when I did, the router w...
Mar 14, 2018Guru - Experienced User
I recommend you phone contact NG support and get help on this. You may have a faulty unit or power adapter.
- OrbibrickMar 14, 2018AspirantUnfortunately I’m out of both the support window and the 1 year warranty so not much help from Netgear. The green light still comes on in the back so it should be getting power.
- FURRYe38Mar 14, 2018Guru - Experienced User
Well maybe getting power however the volts or amp maybe not enough or it could be out of spec.
I would test the power adatper at the tip with a multi meter. Try a different one if you can find a adapter with same volts and amps.
Be sure to hold in the reset button for 10-15 seconds and have a wired PC connected to the back of the router and see if you gain access to the web page set up.
- OrbibrickMar 14, 2018AspirantI tested the voltage and it was fine on the routers adapter, not sure how to test for amps without cutting into the cable. I used the adapters from both the satellites with the same Volts and amps and got the same behavior.
Holding the reset button longer still does nothing unfortunately.
