jtay
Nov 30, 2019Aspirant
RBR50 Bridge VLAN tied to Satellite wired interface
Hi everyone! Just got my new Orbi RBR50 today with a satellite. I have IPTV which requires VLAN 20 priority 4, but when I enable this in the settings, I can only select to associate this with th...
CrimpOn
Nov 30, 2019Guru - Experienced User
I have not enabled VLAN, but I notice that there are two choices: by Bridge Group and By Tag Group. Looks like the Tag Group applies to wireless as well.
jtay
Thanks for your reply CrimpOn !
I checked the tag group options, but seems that when adding another tag group the only options I have are to tie to at least one of the 3 wired ports on the router and not the satellite.
So it seems that the very first (or only) VLAN defined takes all wireless + wired ports
Any other VLAN I try to add, has to tie to wired, and it has to be a wired port on the router unit.
Will try contact tech support. Thanks again!
- CrimpOnNov 30, 2019Guru - Experienced User
Please report what they tell you.
The Help instructions seem inconsistent to me.
Would like to hear "how IPTV works."
