note8guy
Sep 03, 2018Guide
RBR50 Bv2.1.4.16 mine just rebooted again!
I have had it with system. I am constantly getting disconnected from my note 8, maintaining a constant stream to my sonos wth spotify is a hit hit or miss and now BOTH the router and satiile just cr...
Sep 04, 2018Guru - Experienced User
What is the Mfr and model# of the IP modem the NG router is connected too?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
note8guy wrote:
I have had it with system. I am constantly getting disconnected from my note 8, maintaining a constant stream to my sonos wth spotify is a hit hit or miss and now BOTH the router and satiile just crashed and rebooted. The family is home for the holiday, could this $500+ CAD peice of junk not handle the numbr of deivces connected? I have 35 in total which should be handled by this "Mesh" system. Most of my friends have the goole wifi system and they have now comlaints. It is very embarasing havnig them come over and wait for a connection on this thing.
What is the secret to achive some stablity ?
Blanca_O
Sep 11, 2018NETGEAR Employee Retired
Hi note8guy,
We’d greatly appreciate hearing your feedback letting us know if the information Streak2 and FURRYe38 provided has helped resolve your issue or if you need further assistance.
Blanca
Community Team
- note8guySep 11, 2018GuideHi sorry it has been a busy few weeks. I will respond to your solution and questions this evening.
Pat- FURRYe38Sep 12, 2018Guru - Experienced User
Let us know...:smileywink:
Pat- Blanca_OOct 07, 2018NETGEAR Employee Retired
Hi note8guy,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
There is a new firmware released for RBK50. Please update the firmware to 2.2.1.210.
Blanca
Community Team
- FURRYe38Oct 07, 2018Guru - Experienced User
Any progress on this?
Pat- note8guyOct 07, 2018GuideHi not much unfortunately. I do have 30days uptime on both devices but I have had a few situations where my phone and a few other devices have lost wireless connections. I am out of town now and have not had a chance to factory reset the unit. My issue with that is that I will need to rejoin most of my devices to the network even if I use the same ssid and password... Its a real pain.
I see that a new firmware has been released so I will review what the changes are and decide if I will upgrade and factory reset.
To answer some of the questions above I do have many networks in my neighborhood and selected the lest busiest ch. I believe it was 6, I will confirm tomorrow.
Sorry I haven't provided feedback sooner...
Patrick
