tedapke
Apr 15, 2022Follower
RBR50 can’t connect from LAN ports to Wi-Fi connections
I’m trying to run a backup server in my network but it fails to connect to any of the devices that are on Wi-Fi. While debugging the problem I found that I can ping from a laptop on the Wi-Fi ...
CrimpOn
Apr 15, 2022Guru - Experienced User
This is not my experience on an RBR50 system. All devices ping all other devices (as long as they respond to ICMP requests. some do not.)
It is a bit unusual for the IP address to be the same for both the Ethernet and WiFi connections, as they have different MAC addresses and would be seen as different devices by the Orbi. (unless there are entries in the LAN assignment table assigning the same IP to both MAC addresses.)
