tedapke
Apr 15, 2022Follower
RBR50 can’t connect from LAN ports to Wi-Fi connections
I’m trying to run a backup server in my network but it fails to connect to any of the devices that are on Wi-Fi. While debugging the problem I found that I can ping from a laptop on the Wi-Fi ...
Mikey94025
Apr 17, 2022Hero
tedapke wrote:While debugging the problem I found that I can ping from a laptop on the Wi-Fi to a device on the lan ports but not the other way, lan to Wi-Fi. If I move the laptop to the lan the ping works. Note that the ip assigned to the laptop remains the same whether on Wi-Fi or lan. It seems like the ARPs aren’t crossing from Wi-Fi to LAN but I haven’t verified that.
Can you describe your network layout, including any switches, from your ISP/modem to your Orbi RBR and Orbi RBS satellites? Where are your hardwired devices, that cannot ping wireless devices, connected to?
