thetwin
Mar 10, 2018Aspirant
RBR50 cannot find one of its two satellites (RBS50)
I have two RBS50 satellites connecting to RBR50. One of the satellites closer to the router failed to connect. Sync did work. The white light flashed but did not progress to any color lights. None o...
thetwin
Mar 11, 2018Aspirant
Clarification: Sync did not work even when placed next to the RBR50. Not able to get any solid colors. It flashed white for a bit and then nothing. Not able to get to the IP directly either (makes sense when the satellite is not even on the Connected Devices list).
Any suggestions? Or is it time to return this? Thanks.
- FURRYe38Mar 11, 2018Guru - Experienced User
Is Daisy Chain feature enabled on the router?
I would turn OFF the 1st Satellite and then try to attache the 2nd one.
How big is the building? You may not need both satellites?
- thetwinMar 11, 2018Aspirant
I think Daisy Chain feature was on by default. I was not able to make it work consistently either way.
This three-piece kit is used in the home office environment where one of the satellites hosts wired ARLO cameras and SmartThings. The second satellite is in the home office (not in the main house). It has its own wired connections including NAS. Hence, the need for both.
Actually, we have been having issues with this Orbi kit for a while now. I had to reboot them often but have not spent the time to look into it. Despite these recent issues, I really like the performance, feature set, and ease of administration.
Thanks also for your input. Cheers.
