pbarham
Feb 22, 2021Apprentice
RBR50 Can't check for firmware updates
My RBR50 no longer seems to be able to check for firmware updates and says "Service Unreachable": Any ideas on how to fix this?
Feb 22, 2021Guru - Experienced User
What modem/gateway are you connected to?
- pbarhamFeb 22, 2021Apprentice
Standard Xfinity Xfi supplied cable modem ... (with its WiFi access point functionality turned off). That seems to be working just fine for everything else.
- plemansFeb 22, 2021Guru - Experienced User
Turning off the wifi doesn't turn off the router functions of the xfinity equipment. It puts you in a double nat.
What is Double NAT? | Answer | NETGEAR Support
it can cause issues.
How to fix issues with Double NAT | Answer | NETGEAR Support
Yes, it's in 'Bridge Mode'
