pbarham
Feb 22, 2021Apprentice
RBR50 Can't check for firmware updates
My RBR50 no longer seems to be able to check for firmware updates and says "Service Unreachable": Any ideas on how to fix this?
vajim
Feb 22, 2021Master
how are you checking...pc login or app?
pbarham
vajim wrote:how are you checking...pc login or app?
Same with both. The screenshot was from the web admin interface.
If I use the iPhone app it says "checkig for update - this may take 5 minutes" and then tells me that checking for updates failed.
- vajimFeb 22, 2021Master
perhaps reboot all...modem, router, router, sats....and see if that helps
